Lighthouse
User
- Messages
- 1
- Reaction score
- 0
- Points
- 1
Can anyone assist me in what oil filters this Mitsubishi 6D22-TC uses? The data tag reads total cyl vol 11149cc (680cu.in) out put 315 hp / 1800 rpm Valve clearance (cold) Inlet 0.4mm(0.016in) exhaust 0.6mm(0.024in) Firing order 1-5-3-6-2-4 Fuel injection timing 15° BTDC. This engine is for a 200kW 480V generator. The oil filter should be a canister style and uses 2. Thank you in advance for your help.
